Who can rebuild a 1963 Borg Warner transmission
  • Chester C.
    • May 30, 2013
    • 154
    Can someone recommend a good transmission builder. Are there any in the driveline. I've looked but could not find. Plenty of people that do rear ends but trans not so many.
  • Joe R.
    • August 1, 1976
    • 4546
    Re: Who can rebuild a 1963 Borg Warner transmission
    Danny's Transmissions over in the Carolina's is good!
    Darrel's at J. T. Pipers is good but not very economical.
    I have the parts and gaskets if you want to do it yourself.
    JR
    • Keith B.
      • September 16, 2014
      • 1555
      Do you have any local trans shops, how about any dirt tracks. Most of the dirt track cars use newer B/W 3 or 4 speeds. And surly someone is building them. I have a local junk yard that is top notch when it comes to building 4 speeds
      • Dan P.
        • December 1, 1990
        • 683
        Larry at D&L Transmission in NY . Very knowledgeable on early T10's 5one6 4two9 684zero
        • Edward B.
          • January 1, 1988
          • 537
          Suggestions might be more helpful if we knew where you are located. In any event, my recommendation is for D&L, Huntington, NY.
          • Joseph S.
            • October 28, 2014
            • 180
            D & L provides an excellent rebuild kit, and any parts you may need. Danny is also great help if you want to tackle it yourself
            • Chester C.
              • May 30, 2013
              • 154
              I plan on trying him Monday, thanks. Problem is, I put new sliders and brass rings in and I must of did something wrong as it will not go into 2nd. The other gears are fine but second gear the teeth grind like I'm not pushing in the clutch.
