C4 Side door glass outer seal strip - NCRS Discussion Boards
  • Art B.
    • 333
    I need to replace the drivers side outer seal strip. The passenger side is still like new but the drivers side has deteriorated due to repeated up and down movement of the glass and my arm resting on it while driving. The parts are coming and I have some magazine clippings on how to do it. Have any of you actually replaced this item and how much of a job is it?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: C4 Side door glass outer seal strip
    Art, I know I replaced one on my 87 years ago. I don't remember it being a big job but it's been a long time.
      • 43289
      Originally posted by Art Bruns (15355)
      I need to replace the drivers side outer seal strip. The passenger side is still like new but the drivers side has deteriorated due to repeated up and down movement of the glass. The parts are coming and I have some magazine clippings on how to do it. Have any of you actually replaced this item and how much of a job is it?
      Art------
      I can't help with installation pointers. However, I can tell you this:
      You need to maintain the weatherstrip using GM #12345579 silicone dielectric grease. This needs to be rubbed well into the weatherstrip material for all of the soft weatherstrips on the car. If you had done this, you might not be replacing the weatherstrip now.
      • Keith B.
        • September 15, 2014
        • 1604
        when drilling out the rivets put a stop on the drill bit so you don't drill through the door skin. make sure all the clips are lined up and the molding is straight. once you bend it its basically junk. good luck
        • Art B.
          • 333
          I was supplied with the pop rivets to replace the drilled out rivets. But I was wondering if I could use small sheet metal screws instead? Also, is it necessary to remove the side glass itself in order to get at the attaching points?
          • Keith B.
            • 1604
            On my 94 and a 91 I did I did not have to remove the glass. I would use the pop rivets. There is not much space there and I think the tip of the screw might go into the door skin
            • John M.
              • November 1, 1988
              • 170
              Art,
              Corvette Central has a newsletter that I subscribe to (you can too) which in their latest one has an excellent Tech Article on the replacement of the 1984-96 Door Outside Seal Strip. Just what you want to do, step by step, and pictures to go with it.
              Access it at corvettecentral.com where you can subscribe to the newsletter for the cost of a mouse click, or just look for the category C4 and the C4 (84-96) Archives / CC Tech, where you will find the article on replacing the door outside seal. Good Luck.
              Save the Wave ................. JGM
              • Art B.
                • 333
                Thanks, John. I found it.
