C2 Shifter - NCRS Discussion Boards
C2 Shifter
  • Lawrence S.
    • April 1, 1993
    • 801
    C2 Shifter
    Given a new shifter, is there any difference in the "feel" of the shifter if you hook up the linkage for the short throw vs. the long throw?
    Lawrence
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 Shifter
    The only thing I notice it takes a bit more effort. Otherwise no issue. Still not as short a throw as say a Tremec TKO 5 speed.
    • Bill K.
      • June 27, 2013
      • 48
      Re: C2 Shifter
      I agree, moved mine from short to long for judging. Long effort is less. I did find myself having to ensure I pushed it all the way into gear vs what i was used to when set to short throw.
      • Lawrence S.
        • April 1, 1993
        • 801
        Re: C2 Shifter
        I rebuilt my original shifter, and it does not shift as smooth as my friends shifter that is long throw. I may change it to long throw and see how it feels. I just am not sure if my rebuilt shifter is a smooth as it should. Seems a little "chunky". Definitely harder to shift in short throw.
        Thanks for the input guys
        Lawrence
        • Gene M.
          • April 1, 1985
          • 4232
          Re: C2 Shifter
          Lawrence
          Lawrence, When the center hardened tip on the bottom wears the pressure angle gets tilted a bit. The "chunky" you refer to is common. A rebuild even replacing all the shifter gate plates still does not remedy all as you experienced. In MHO the only solution is replacing the shifter main shaft too when a lot of wear is present, especially in short throw. But then again it becomes so close to a total replacement.
          • Lawrence S.
            • April 1, 1993
            • 801
            Re: C2 Shifter
            I was browsing Zip and LI Supply for shifters and what I saw was just the plates at LI. Zip had an entire shifter including the shift lever. I just need the shifter for a smoothe shift. Any recommendations on where to get one?
            • Leif A.
              • August 31, 1997
              • 3632
              Re: C2 Shifter
              Here ya go. Item #4009
              Corvette parts and services for all years, specializing in 1963-1982. 40+ years experience. Located in Linesville, PA. Same location since 1970.
              Leif
