70 lower control arm big problem - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Well everything was going too well.
    I went to torque the lower control arm to the frame on the driver's side. My AIM says 70 ft.lbs for front bolts and 90 ft.lbs for rear bolt. I assume that is correct.
    One of the front bolts stripped before reaching 70 ft. lbs and now I cannot get it back out. Good Grief!
    Any suggestions are appreciated.
    Thank you,
    Bill
    • 43251
    Re: 70 lower control arm big problem
    Thank you,
    Bill
    Bill-------
    There are only two ways that this could happen:
    1) The threads in the bolt or the special nut were bad, or;
    2) Your torque wrench is WAY off.
    I vote for (1).
    As far as getting the bolt out, I really don't see why that's such a problem. I'd just keep turning it counterclockwise while applying down-pressure until it comes out. If that fails, simply remove the other bolt, cut off the head of the stubborn bolt with a die grinder, and remove the nut and headless bolt from the top. This is really not such a big deal since there's no way I'd re-use the nut or bolt, anyway.
    These are SAFETY-RELATED components. Use NEW, high quality bolts and special nut. Safety trumps correct headmarkings.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill-------
      I vote for (1).
      Thank you Joe.
      I had already attempted the downward pressure before the post to no avail. I am in the process of cutting off the head as you suggest. Thankfully the bolt is easily accessible.
      I have a craftsman click type torque wrench so I agree that #1 is most likely. The passenger side assembled without issue.
      Kind Regards,
      Bill
        • 43251
        Thank you Joe.
        Kind Regards,
        Bill
        Bill-------
        You might be able to save the nut with a Heli-Coil on the thread-damaged side.
        • Bill L.
          • February 1, 2004
          • 1403
          Thank you Joe.
          Certainly will consider the Heli-Coil option.
          Kind Regards,
          Bill
          • Bill L.
            • February 1, 2004
            • 1403
            Bill-------
            HI Joe,
            What is the correct finish on the nut? I thought plain.
            Bill
              • 43251
              HI Joe,
              Bill
              Bill------
              Yup, plain, non-plated steel. This was GM's very poor choice for this part which is highly exposed to the elements.
