Z07 brakes - NCRS Discussion Boards
Z07 brakes
  • Tim S.
    • March 1, 1989
    • 124
    Z07 brakes
    The 73-75 Z07 and maybe FE7option package , as I understand it, included both front and rear dual pin calipers. Can anyone tell me if the rear calipers had a stiffening bracket requirement included ?
    I do not have an Assembly Manual for these years. Any pictures would be appreciated
    Thank You
    • 43222
    Re: Z07 brakes
    Thank You
    Tim------
    No, the J-56 brakes used from 1966 to 1975, including those part of the Z-07 package never used reinforcing brackets for the rear calipers. The brackets were used only for the front calipers.
    By the way, J-56 was not included as part of FE-7. FE-7, like F-40 and F-41, was only a HD suspension option.
    • Tim S.
      • March 1, 1989
      • 124
      Re: Z07 brakes
      Tim------
      Thank You Joe
      • Tim S.
        • March 1, 1989
        • 124
        Re: Z07 brakes
        Joe do you know if the front and rear dual pin calipers use the same brake pad? I know the rear caliper has smaller pistons.
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: Z07 brakes
          AFAIK, the rear calipers on the heavy duty brake & suspension packages never used dual pins to hold the pad in place. Only the pad material, and (probably) the backing plate and attaching method (material-to-plate) was different on the rears.
          Notice on the attached pics that the pad material is the same (orange ink stamp "903 FF") and they are bonded, not riveted to the backing plate. I would expect that the plate on the rears is also of that heat-resistant material (Inconel ?)
            • 43222
            Re: Z07 brakes
            Tim------
            As Wayne mentions, the rear J-56 did not use dual pin calipers. However, you will sometimes see dual pin pads on the rear. These are either single pin calipers that have been converted (easy to do) OR I think dual pin calipers MIGHT have been used on some 1969 Camaros with 4 wheel disc brake option.
            • Tim S.
              • March 1, 1989
              • 124
              Re: Z07 brakes
              Wayne & Joe
              I will try to post a picture of the rear dual pin calipers this PM.
