If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Gary - The compressor back plate on our Sept 66, S/N 1476, build 67 reads
C220
6555302
R 15
I checked some other Chevrolet/Chevelle AC compressors that I have & there are other formats but the # 6555302 appears on the rear flange of the compressors I checked & the '67 NCRS TIM&JG does indicate part # 6555302 is cast into it below the casting date & there is a photo of the rear flange. Unfortunately, I have not checked other '67 Corvette AC compressor rear flanges so I don't know if other configurations exist.
Peter,
C 22 0 cast under the manifold would be: C=March, 22 = day, O = 1970. The 6555302 was on all that did not have the thermal switch. (I) is also used on the casting date.
Hi Gary, sorry didn't get back top you yesterday. I worked on my truck till around 8:30 last night and got to go finish it up hopefully in a little while. Anyway, I think you are OK with the L10 date on your compressor but I think there should be a 6 after the 10 for 1966. Domenic might can chime in on that and let us know for sure. Our compressor has a date of L156 which is Dec 15 1966 for my wife's Feb. 67 vette. The sticker on top of the compressor also has a date of 122262 which is Dec 22 1966 2nd shift I believe.
Hi AL,
Hope all is blowing cold, The clincher here is that the casting dates are raised letters and my guess is that the only one that is raised is the A-1. The long casting number is recessed and L10 would also be recessed if I am correct. No one has figured out the letters and numbers under the long casting numbers yet. I think those may be a batch number or shift.
Peter,
Dom
Here's an example of the cast letter "I" (September), and the number "1" in the 15 (day of month) 4 = 1964.. I believe the I or 1 used the same character.
PS: the original picture was shot in portrait format, but it seems that DB software rotates to panorama, and I don't know how to override.
