If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
On Craigslist, S.F. Bay Area, an auto parts ad says this engine was removed from a boat 25 years ago. The ad says the block is #3916321, and the heads are 3964291." Hi Perf" is on the heads and block.
