Oil for 327 - NCRS Discussion Boards
Oil for 327
  • Michael K.
    • January 14, 2013
    • 99
    Oil for 327
    What motor oil(s) do you have most overall confidence in that contain zinc and other components designed for c-2 engines. I have been using Brad Penn but am concerned it is a partial synthetic. I don't want to add an additive to the oil. Thanks! Michael Kalogridis
  • David K.
    • September 30, 1992
    • 281
    Re: Oil for 327
    I'm running Rotella 15-40 non synthetic in my 65' 365hp car with no problems.
    • Mike M.
      • May 31, 1974
      • 8389
      Re: Oil for 327
      i too use rotella. get it in gallon jugs at local tractor supply when its on sale, leaving more change for the beast.inthe past, esso had a high zinc oil for diesel engines that i always used till its availability went down the tubes. mike
      • Michael J.
        • January 27, 2009
        • 7122
        Re: Oil for 327
        Those are good oils, I have also been using Valvoline Racing VR1 20W-50, it also has high ZDDP content and is about $5/quart.
        • George W.
          • July 31, 1998
          • 322
          Re: Oil for 327
          I, also, use Valvoline Racing VR1 20-50 in my '65 396 Big Block and '61 283 315 hp fuelie.
          I have use it for years and it is easy to get and works well. Try it you will like it.
          Dr. George
          • Ed S.
            • August 6, 2014
            • 1377
            Re: Oil for 327
            Michael,
            That question has been asked by many before you and there has been a great deal said (written) on this subject - and much of it is in forum archives - a lot of good stuff. Allow me to save you some research time - I am attaching two pdf files that should answer all your questions. One article is written by Duke Williams (great article) , the other is a Motor Oil grading guide that will enhance your understanding of oil in general.
            By the way - filters - also discussed a in great length in previous threads; I think you will find that the consensus of members that have been around for a long time advise against using AC 141 reproduction filters. Instead they recommend using a WIX brand filter, # 51143, same filter available from NAPA, their # is 114. Among other things the "cans" on these filters is metal instead of paper like the AC repros.
            Ed
            • Bob W.
              • December 1, 1977
              • 802
              Re: Oil for 327
              Ed I agree the WIX filter seems to be a better quality filter. I never used a NAPA filter so I cant say.
              Bob
              • Russ S.
                • April 30, 1982
                • 2162
                Re: Oil for 327
                Remember when using older threads that things keep changing now days. I have been told that diesel oils which up until recently have the needed ZDDP, but that it is being fazed out of this oil also. I have not researched this so I don't know if it is so or not. My intent here is only to say keep up on these oils when ever you buy more.
                • Ed S.
                  • August 6, 2014
                  • 1377
                  Re: Oil for 327
                  Bob
                  As I understand, the NAPA "is" the WIX filter, with a NAPA pn. Notice the PN contains the same # 114. When I purchased one at a NAPA store I asked the sales clerk and he stated that their parts book indicated that the manufacturer was WIX.
                  Ed
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Re: Oil for 327
                    Russ,
                    I think that may be a myth that has already been debunked. As long as the bottle says API CJ-4 or CI-4, everything is cool from a ZDDP standpoint. But you are right, it pays to stay up on things in case something changes!
                    Joe
                      • 15679
                      Re: Oil for 327
                      Who told you that?
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Re: Oil for 327
                        Brad Penn has an oil designed for older engines that have flat tappet cams.
                        Also STP is a high zinc content as an additive for oils without it. I've always use it with Penzoil 10W30.
                        • Larry M.
                          • January 1, 1992
                          • 2695
                          Re: Oil for 327
                          NAPA Gold #1143. Made by WIX in the USA. Very high quality..................better than most (or all) others on the market. I know Duke likes Baldwin filters, and I am sure they are also very high quality. I don't have their part number handy, but it should be easy to find.
                          Larry
                          • Ed S.
                            • August 6, 2014
                            • 1377
                            Re: Oil for 327
                            Larry
                            I derived this Baldwin filter # from a previous thread. You can use either aBaldwin P18 or P18HD. I could not find Baldwin filters in my area, went with NAPA (aka) WIX.
                            And while we are on the subject of filters - Air Filters; Paper filter for a 64 L76 is the WIX 42070. NAPA # for the exact same filter is 2070, about $9.00 but.... if it is not stocked in your local NAPA store (and probably isn't) then they will charge you a shipping fee from the warehouse - another $8 or $9.
                            Ed
                            • Michael K.
                              • January 14, 2013
                              • 99
                              Re: Oil for 327
                              Thank you all so very much for taking the time to post information. I really appreciate it.
                              Michael Kalogridis
