best way to apply to touch up paint - NCRS Discussion Boards
  • Mike M.
    • July 22, 2015
    • 17
    I have some very small chips on my 1965 vet-I have the original paint.
    my question is what the best way to touch these up?
    Is a small brush best to use?
    thanks
    Mike
  • Douglas L.
    • May 8, 2015
    • 181
    Re: best way to apply to touch up paint
    For very small chips I prefer a toothpick, more control. Also, it usually takes more than one application as it tends to "lay down" after a few minutes.
    • Donald H.
      • November 2, 2009
      • 2589
      I bought some Micro Fine Applicators (see picture). You can find them on Amazon and elsewhere. I've never had success with a typical brush. Also recommended by a friend who is a professional auto painter.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Frank D.
        • December 27, 2007
        • 2703
        I use the ultra-tiny brushes that nail salons use to paint flowers on gals' pinkies.
        They have them on Amazon...I find they let me build up a small chip better than those foam tipped deals.
        I'll even things out a bit with some light wet sanding with 2000 grit or Langka Blob Remover:
        https://www.amazon.com/Langka-LANGKA...lob+eliminator
        A bottle will last you a lifetime.
        • George J.
          • March 1, 1999
          • 775
          The paper end of a match also works well.
          • Sal C.
            • December 1, 1984
            • 430
            Donald's solution is, by far, the best. Once you've used them, you will never use anything else.
              • 11698
              I've tried the Micro Fine Applicators, and in my experience they gave me too large of a "blob" of paint no matter how hard I tried. I moved on to using very tiny brushes which seemed to work better. So, my experience differs from Sal's.
