Which Scissor Jack do C2 owners trust - NCRS Discussion Boards
  • Ed S.
    • August 6, 2014
    • 1390
    After doing some research I determined that the scissor jack that I got with my '64 convert when I purchased it is actually a jack for a 63 -64 Corvair. Threads in this forum's archives and vendor listings suggest that the OEM Type I jack is not very sturdy and should not be used as intended. Vendors selling correct looking Type I repros stipulate that they are "for show only" and are unsafe to used to raise the car. On top of that, the prices for Type I jacks from vendors and E-Bay sellers are ridiculous.
    All that said, my question is, what make, model, year of manufacturer jack ( & vendor source) do member C2 owners trust and carry in their cars that would be safe to use if they had to raise the car to change a tire on the road?
    And.... if anyone knows of a source of a reasonably priced Type I that would be appreciated too. BTW - I have the correct jack handle.
    Thanks for your advice in advance.
    Ed
    • 6960
    Re: Which Scissor Jack do C2 owners trust
    Ed, there was a interesting restorer a while back on the jacks, I have a 63 and a 72, the 63 is not to be trusted, the 72 is a much better jack, but still you'll want the car on level ground. I am thinking sometime 68/69 is when the change occurred to a wider base and thicker arms gussets. But no matter how you look at them its still hokey .
    • Harry S.
      • July 31, 2002
      • 5346
      Ed, I never use my 63 jack, either the original or the repro. If you get a flat call AAA. I use a shop jack at the house with jack stands to change bias-ply to radials.
      • Michael J.
        • January 27, 2009
        • 7175
        +1, this is what I use and carry in the back if I go very far, but AAA is better.
        • Ed S.
          • August 6, 2014
          • 1390
          Edward, Harry, Michael,
          Thanks for the great advice. Looks like I will be in the market for a repro C3 jack soon. Never gave the AAA a thought - but great idea. I wonder if there is an agreement between the NCRS and the AAA - for a possible member discount, will definitely ask.
          thanks again
          Ed
          • Carl N.
            • April 30, 1984
            • 592
            I carry a sizzor jack from 2003 PT Cruiser which was free to me. NOT for judging but for use to change on road. Should be available at local recycling yard cheap. Might also be same jack Neon uses, but do not know for sure. PT is about same ground to frame as mid year and about same weight. Just an idea if you are just looking for jack that works
            • Joe R.
              • July 31, 1976
              • 4552
              There was an article written for "The Restorer" several years back that described the difference between Type I, Type II and Type III jacks. Reading that article will show the difference and the improvement in Type II jacks. They had a stamped reinforcement which MAY have kept them from folding up when in use. John Smith used the article to start building Corvette jacks and they are still available from Bluejacket, OK. All repo jacks have a sleeve and tag that says for Display Purposes Only. Liability release they hope!
              Yep, use AAA for safety.
              JR
              • John D.
                • December 1, 1979
                • 5507
                In the old days when I had my share of midyears the jacks that came with the cars were junk. They used to bend-spread apart etc.
                I bought a similiar style jack from NAPA back then-but heavy duty and it's still around the shop.
                • Gene T.
                  • May 31, 1997
                  • 78
                  Michael..... I owned the very same type of AC Delco floor jack and it started to leak and it failed; just be extremely cautious.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    My car doesn't leave the garage without my triple-A + card and a can of Fix-A-Flat...
                    If conditions were absolutely, positively perfect I might change a tire roadside.
                    Even so, you have to be very, very careful with a scissor jack...I carry a heavy solid rubber Harbor Freight wheel chock, a collapsible 4-way wrench, and, one of those combo rubber mallet/wheel cover removal tool for such occasions.
                    Meaning a secondary road, far off the shoulder, firm and level surface and no traffic....otherwise I'd be many feet from the car on my cell phone.
                    Distracted drivers kill people almost weekly here in Orlando futzing around with a disabled car roadside...
                    • Ed S.
                      • August 6, 2014
                      • 1390
                      You get what you pay for I suppose. I checked the price of AC Delco jacks on the internet, around $50 - they probably aren't all bad but that is not a lot of $ for a device that has to be flawless. Thanks for the tip.
                      Ed
                      • Ed S.
                        • August 6, 2014
                        • 1390
                        I am really glad I asked this rather non-technical (dull) question. I had no idea that these old scissor jacks were such a piece of junk, not to mention all the other great tips posted by members, like Frank's. I learned a lot of valuable info - this is right up there with "carry a fire extinguisher at all times". These tips need to be widely publicized - unless of course I am the only one in the vintage Corvette community that was totally oblivious to the issues - thanks again to all that have posted comments.
                        Ed
                        • Michael J.
                          • January 27, 2009
                          • 7175
                          I'll keep an eye on it, but I have used it frequently for almost 9 years and have had no problems.
                          • James W.
                            • December 1, 1990
                            • 2676
                            Michael,
                            That's the exact same floor jack I carry in my '64 convertible on long trips (Road Tour). It's small is size and came with a plastic hard sided case.
                            James West
                            • Leif A.
                              • August 31, 1997
                              • 3654
                              thanks again
                              Ed,
                              Check your classic cars' insurance policy. Most (mine from Hagerty) have Roadside Service as part of the policy. No need for the additional expense of AAA.
                              Leif
