Favorite Shop/Work Light? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4552
    Talk about disruptive technologies.
    I'm using my incandescent and florescent shop lights less and less. Even though they're ceiling mounted with a recoil cord mechanism, I find myself using small $5 LED lights more and more often. I have some that are handheld, some can be placed on the floor and aimed, and others which are mounted under hood. I even have a $15 Craftsman baseball cap with LEDs mounted in the leading edge of the brim- which can light up a baseball field.
    So my question: What are your favorite shop lights in this brave new world? And what have you done with your old-time 60W incandescent shop light that used to burn your cheeks?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Thomas S.
    • February 7, 2016
    • 618
    Re: Favorite Shop/Work Light?
    There is no substitution for a plain old incandesent lamp but. . . . .
    they get too hot
    they can shatter causing glass to fly around
    fire hazard
    Fluorescents are give off a funky washed out light that is usually even but dim.
    Inexpensive LED's are very directional, don't spread well. Because of the narrow focus, they tend create hash shadows. If you spend a bit more on an LED light with multichip driver that will take care of the narrow focus. Having some adjustment to the brightness is also a plus.
    I use a light made by Milwaukee Tool that uses an 18-volt lithium batter, the same one that they use for some of their power tools. Pictures,are attached. The larger sixe battery will give you about 2-3 hours of light and there are two lighting levels. it's god to have an extra battery charged because unlike most other batteries, lithium batteries don't give you a warning when they are about to die - they just stop supplying power.
    the engine images were taken in my garage at night with no other light on.
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • Edward B.
      • January 1, 1988
      • 537
      My big overhead fluorescent lights have been working fine for 40+ years with only an occasional tube replacement; I see no reason to change. Supplemental lighting, when needed, is provided by a trusty incandescent "trouble light," metal cage and all .
      • Stephen L.
        • August 29, 2007
        • 205
        try a head lamp (like what a miner would wear) - it is incredibly convenient and keeps hands completely free - no need to pause and readjust - incredibly bright, focusable, various intensities, rechargeable - really like it - this one is expensive...there are many much cheaper (but not as bright - this was the brightest i could find)
        Coast HL8R 800
          • 6942
          Mark, LED technology is made leaps and bounds as of the last few years and I have a automotive shop and that's all we use, just plug in or rest on a charging pad when not using. batterys generally last up 5/6 hrs on a single charge. and brightness is great, there are many makers, I find the best lights just rest on a pad, this way grease does not get into a small charging port on the handles, like many makers do.
          • Mark E.
            • April 1, 1993
            • 4552
            Thanks Thomas. I might have to get one of these.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Mark E.
              • April 1, 1993
              • 4552
              There are some nice head mounted work lights. Perfect for the jobs where you're on your back looking up at a dark chassis.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Michael J.
                • January 27, 2009
                • 7122
                I use some LED track lights in a strip with magnets that I attach to my lift rails under my car. Good illumination for the entire chassis area, which always seems to be where the issues are.......
                Discover Real Garage Life, your trusted source for high-quality 2 post and 4 post car lifts. Our lifts are designed for low garage ceilings, car collectors, car restoration specialists, and DIY Automotive Enthusiasts.
                • Mark E.
                  • April 1, 1993
                  • 4552
                  http://advantagelifts.us/LL-170-Lift-Lights
                  Awesome! Leave it up to you Michael to show off the cool, hi-tech way to do this.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • John D.
                    • December 1, 1979
                    • 5507
                    LED all the way. Or you think so anyhow. Be very careful using those LED lights.
                    As Chairman of the Pittsburgh chapter show recently I (the chapter) bought all the judges, tabulators, and workers a really nice LED flashlight. 2000 Lums. Adjustable ray. But the night before the show I had to put batteries in all of them. Shined one in my eyes and thought I was going to go blind. Saw spots for about 10 minutes.
                    In my shop I switched to all LED flashlights. Really a bonus. For Christmas my sister bought my son and I a Stanley LED flashlight that stands on a tri-pod. Talk about a cool light. When the electric went out the past week (multiple times) The LED lights were a life saver.
                    Great for judging also. JD
                    • Keith W.
                      • June 30, 1998
                      • 375
                      Craftman hat with LED good for some jobs, hands free or you can upgrade with the flash light in your mouth trick - yes we've all been there
                      • Mark S.
                        • July 31, 1983
                        • 660
                        Just a word of caution. If you use a flashlight in your mouth, you may want to use a plastic one. I have chipped my front teeth with a metal LED flashlight; and my dentist was not happy.
