If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Is there a point deduction for using replacement clips, which have octagon bolt head, rather than the original square one? If so, does anyone know where to found them? Thanks
Plan on paying $40-$80 per clip. They are not easily found and I have an identifying dimple on the back end of them. They are a square nut with swashed ends.
