63 Heater Coolant Circuit
  • Thomas S.
    • February 7, 2016
    • 576
    On a non-AC 327/340 hp 63, does coolant always flow through the heater regardless of the temperature control position on the dash?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
  • Leif A.
    • September 1, 1997
    • 3567
    Re: 63 Heater Coolant Circuit
    Thru the heater core...yes.
    Leif
    • Timothy B.
      • May 1, 1983
      • 5172
      Thomas,
      Yes it does.
        • September 16, 2008
        • 6939
        Tom, If your feeling heat through the ducts while traveling at hwy. speeds chances are the Blend door seal has deteriorated and is letting the hot air flow by the door. I just had my 63 inside heater box out and repaired the seal on this door.
        • Thomas S.
          • February 7, 2016
          • 576
          Thats a real job getting the box out. I have a minimal amout of hot air to deal with and it a convertible. The question arose when I was doing a complete coolant flush and I noticed a full flow through the heating coils no matter what position the temperature pull was in.
          So it's not a critical item on the to-do list. I never noticed the heat in the first place.
