1963 Corvette Fender Louvers - NCRS Discussion Boards
  • Lawrence E.
    • November 7, 2013
    • 23
    Hello
    Are the 1963 Corvette Fender Louvers supposed to be high gloss or low gloss?
    thanks, Larry
    • 43222
    Re: 1963 Corvette Fender Louvers
    Originally posted by Lawrence L Elmore Jr (59157)
    Hello
    thanks, Larry
    Larry------
    1963 Corvettes did not have fender louvers. If you are referring to the "simulated louvers" on the front fenders, they were painted with the rest of the car. So, the paint is no different than it was on any other part of the body.
    • Dan H.
      • July 31, 1977
      • 1369
      Seems I remember that the above the split line upper surfaces were only areas buffed, the louver area would be 'as sprayed' to be really authentic, not glossy as in clear coat etc. used today.
      Dan
      1964 Red FI Coupe, DUNTOV '09
      • Loren L.
        • April 30, 1976
        • 4104
        Hopefully, the lower front valence in the parking light area even got painted.
        • Dan H.
          • July 31, 1977
          • 1369
          or the bottom of the rear quarter panels?
          • Lawrence E.
            • November 7, 2013
            • 23
            Thanks Guys -- it sounds like from the louvers paint requirement, I'm in good shape ...
            • Harry S.
              • July 31, 2002
              • 5309
              Larry, The Florida Chapter has many members that are familiar with the judging of the paint application process. Depending on where you live in Florida I suggest you chat with an experienced Exterior Judge about how the paint should look. Have him look at your car, I see that it got a TF this year so you are probably OK. What was your paint deduction, it was either 0%, 20%, 50% or 100%.
