Type grease head light pivots - NCRS Discussion Boards
  • Carl B.
    • March 1, 2007
    • 89
    I am finally ready to install rt. side head light bucket. I have two types of chassis grease, Small bucket inherited from my uncle years ago. Agway No. 2 multi service grease or Mobil ! synthetic grease. Also question, were pivots greased on assembly line during production?
    • 43222
    Re: Type grease head light pivots
    Carl------
    I think you could use either of the two greases you have and be fine. If it were me, I'd use the Mobil 1 synthetic.
    The pivots were lubricated at St. Louis. Motor oil was used. The felt seal was saturated with the oil.
    • Jim D.
      • 2884
      I've used Lubriplate with great success.
        • 15680
        Mobil 1 should work well, and since the base oils have lower volatility that conventional base oils the grease will remain functional longer.
        I should also point out that grease has a shelf life. Over time the oil will separate from the solid "soap", which is often seen as a small pool of liquid oil at the top of the can, and there no real way to remix it in the field, so you should probably dispose of the bucket of grease you got from your uncle.
        It's best to buy grease in small amounts and replace it at least every five years if it has not been used by then.
          • 15680
          My understanding is that GM "Lubriplate" is basically a NGLI #2 white lithium grease with a conventional oil base. In my experience it dries out very rapidly, which is why I prefer a synthetic base oil for "long life" lubrication jobs.
          • Jack J.
            • July 31, 2000
            • 640
            Anyone familiar with DuPont Krytox GPL 105 (general purpose lubricant [oil]? And would that work for the pivots/felts? Jack J
            • Carl B.
              • March 1, 2007
              • 89
              sorry to be a bother. I can not figure out how the retainer springs are installed on head light motor armature. Thanks for all the help so far
