Okay, I just installed my rear suspension on my restored frame (no body on the frame). After I installed the rear spring (the last thing I did) I can only get a 1/4 turn out of the rear end, prior too this everything turned freely. My question is this because of the angle on the suspension since the trailing arms are hanging (frame is on jack stands) and maybe the half shafts are hitting (I don't see any place where their hitting)? Is this normal?
Rear end binding frame off?
Re: Rear end binding frame off?
I installed the shocks (new delco's) before the rear spring, I saved the spring for last. It's just weird that nothing was binding until the spring was installed, but that spring does really pull down on the trailing arms. So if their is a problem I want to address it now.- Top
I recently finished the chassis on my 66. I did have binding like you describe, but I was very concerned with the stress on all the rear suspension with no body on. I was especially concerned with how the strut rod were twisted by the force if the spring. I used ratchet straps to pull the spring and trailing arms up to a more normal level. You might try this and see if you still have binding.Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Check what you have installed. They indicate this excessive travel will create issues and will void their trailing arm rebuild warranty.
Larry- Top
Hi Don, yes I noticed the strut rods have a slight twist, when you pulled the suspension to more of a ride height did this solve your binding problem? I plan on taking the frame off jack stands today and putting it on car dollies to move around.- Top
Brian -
No need to check shock length/travel - your half-shaft U-joints are binding due to the rear suspension being in full rebound due to not having any weight on the rear of the chassis. Jack up the trailing arm on each side far enough to insert a 5/8" socket between the bottom of the trailing arm and the bottom of the clearance slot for the trailing arm in the frame, and the half-shaft binding will disappear.- Top
Brian -
I know I checked the rear shocks per Bair's advice and my new (but very old stock) Delco ones were fine. I also did not experience half-shaft binding when car was later raised again for other work.
FWIW.
Larry- Top
