Hi:
I just wanted to mention some work I had done at K&B Special Products here in Georgia. Ken, the owner has now restored two very important components on my '67 coupe--- the radio and the main gauge cluster.
His work is simply "OUTSTANDING". I am posting some photos of his work here so you can get an idea of the quality that this guy maintains.
THANKS KEN!!!!
Here is the finished - reworked radio: it plays flawlessly and the tone and sound are both clear and correct!!!
This is photo of the main gauge cluster prior to restoration....
The speed minder did not work---- the temp gauge was intermittent in its operation and almost every gauge was mis-aligned....much wear and tear from years of service had taken its toll.
The finished product----- all small gauges were replaced, the tach and speedo were both good so they remained as is (both were in pristine condition)..... and of course the black finish on the panel was re-done------
----- and the back of the cluster --- Ken was able to salvage the original tag --- it had been over-laid with a repair shop sticker from some time in 1975 !!!! ---- but as you can see it is mostly intact and clearly readable.
I hope you enjoyed this little side journey --- and as I mentioned Ken at K&B is really quite good!!!
(Still a few more projects left to go on this old '67 but its getting there!!!!)
Regards
Bill
THANKS KEN!!!!
Regards
Bill
