54 Soft Top Frame - NCRS Discussion Boards
54 Soft Top Frame
  • Eric F.
    • June 30, 2003
    • 319
    54 Soft Top Frame
    I'm restoring a 54 soft top frame and I've run into an area in question. I've checked the archives and archived restorer articles. I've also looked at several online photos of the rear bow but can't find the answer to my question.
    Both rear latches were attached with machine screws that went through the rear bow and attached to nuts. This seemed strange because the nuts could be seen through the soft top fabric. I suspect the machine screws were originally secured to threads inside the rear bow that were fastened via T- nuts or in some other ridged manner. Does anyone know for sure? I've attached a photo of the latch I'm referring to and a photo of the rear bow (from the outside view) which shows the holes drilled through the bow, allowing the machine screws to accept nuts or something similar. Any assistance is greatly appreciated.
    Eric
  • Terry D.
    • May 31, 1987
    • 2698
    Re: 54 Soft Top Frame
    Call Coffmans Corvette, ask for Clint, great guy and knows all about corvette tops,,,419-522-2246
    • Guy M.
      • November 1, 1993
      • 500
      The screws go into the insert built into the frame. I imagine they get screw up over time. If they are shot then it would seem that nuts might be needed to hold them on. I don't know if the inserts can be restored, seems unlikely. Mine were fine so lucky me.
