If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Would someone be able to measure the shape of the corners of the headlight door opening for me? If you could tell me what diameter of drill bit matches the shape it would be helpful.
I measured my corner openings using a drill bit. As far as I could tell it appears that a 1/2" drill bit is very close which works out to a 1/4"radius.
Randy, I don't think a drill bit would be a good idea, I would just carefully take a small round file or maybe a Dremel tool to get the desired fit. Steve or Enzo's fit are perfect.
