Water Temp gauge acting odd in an '81
  • Michael J.
    • January 27, 2009
    • 7034
    I have been having a funny problem with my '81's water temp gauge. When it is cold and just started, it pegs all the way right, way past the 250, but when I drive it a while and it warms up, it goes back to working properly and accurately. Any ideas what is going on? Thanks.
    • September 16, 2008
    • 6939
    Re: Water Temp gauge acting odd in an '81
    Mike, try to un-plug sender when cold and take a test light and ground it to block, then the touch the terminal with key on, generally the gauge will go up half way, (the bulb in test light acts a resistor) and see what happens, But sounds like the sender to me. This is a quick test of circuit and gauge.
    • David H.
      • July 1, 2001
      • 1435
      Michael,
      Any chance it could be the resistor on the back of the gauge going wonky?
      • Michael J.
        • January 27, 2009
        • 7034
        Thanks guys. Ed, when I unplug the wire at the sending unit, nothing happens, the gauge stays pegged over to the right before and after starting. David, that could well be the issue, thanks!
          • 6939
          Mike try a test light on the plug with the key on, you should see the gauge move to about to middle of the sweep. The temp. sender works like the rheostat on a light switch at home works on the same principal, turn the dial up and the light gets brighter . just to make it as simple as possible. sounds like there's a open in sender til the temp gets to a certain point.
          • Michael J.
            • January 27, 2009
            • 7034
            Thanks Ed, I tried that and nothing happened to the gauge needle, still pegged over way past 260.
