If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
The JM states the hood weather strip should wrap around to approximately even with the hood latch pin, but there is a photo showing it stopping before the bend. Which is correct?
