I am doing a frame off restoration on a 69 350/350 and am having the motor gone through at this time. The engine did not have the two wire supports that are mounted on each side. I have NOS supports: 1 is zinc plated and looks to be dipped in black plastic about 1 inch from the end with the notches for the wires and 1 is painted black with a rubber grommet to hold the wires. Questions:1 Are the supports installed as they are (zinc plated and black paint) or engine orange and 2 What finish are on the bolts that are used to attach the supports to the block?
Thanks for any help Steve
