C1 Rear Shock Hanger Bracket - NCRS Discussion Boards
  • Eric E.
    • November 1, 1998
    • 254
    I am trying to salvage a couple of hanger brackets. While one has a couple of stripped holes I have two that just have broken bolts. Before I put the effort in removing the bolts, are the eye pins pressed into the large diameter opening in the bracket or are these just the typical rust fit? I had to cut the pins out to remove the leaf springs. Thanks as always!
  • Terry D.
    • May 31, 1987
    • 2692
    Re: C1 Rear Shock Hanger Bracket
    Eric
    The eye pins are knurled so it is sort of a pressed fit but nothing that requires a press. Probably want to soak them in some sort of penetrating oil or heat them with a torch before trying to pound them out.
    • Eric E.
      • November 1, 1998
      • 254
      Thanks Terry, nice to know what I am getting into before I take a whack at it. Most things that I have been dealing with are a lot tighter than you would expect. Have them soaking right now.
