1966 c2 front and rear brake rotors
  • Jef S.
    • December 15, 2010
    • 118
    WHAT IS THE DIFFERENCE BETWEEN THE FRONT AND REAR BRAKE ROTORS ON C2s.
  • Joe R.
    • August 1, 1976
    • 4546
    Re: 1966 c2 front and rear brake rotors
    The rear rotors have been machined inside for the emergency brake shoes to contact and maybe hold your C-2--Maybe!
    JR
    • Michael W.
      • April 1, 1997
      • 4290
      The offset from the spindle/hub face to the rotor surface is different.
      Rear rotors have an extra hole for access to the p/brake adjustment.
      • Jef S.
        • December 15, 2010
        • 118
        Yes thank you for the help that makes sense. My car was partially disassembled in the mid 70s doping out all the nuances are challenging at times
          • 43129
          Jef-------
          One other thing: front rotors were never available from GM except as an assembly with a riveted-on hub. They were (and remain) available from AC-Delco, though, as rotors only. These are not OEM-quality rotors, but aftermarket quality.
          • Jef S.
            • December 15, 2010
            • 118
            Thanks for the help
