Headlights - NCRS Discussion Boards
Headlights
  • Roger D.
    • June 3, 2014
    • 180
    Headlights
    I am restoring my 1969 headlights. I want to use the original pivot brackets with the plastic ball. Does anyone restsore these units. I do not want to use the new stamped steel ones.
    Thank you
    Roger
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Headlights
    Is there something wrong with the plastic brg?
    • Roger D.
      • June 3, 2014
      • 180
      Re: Headlights
      Yes they are worn to the point that there is to much side play and movement that can cause improper gaps as well as chipping paint when going up and down. That would be a major problem to fix at that point. New fittings would not allow for excessive play and would assure no paint chipping when setup properly with the correct gaps.
      • Russ S.
        • April 30, 1982
        • 2162
        Re: Headlights
        If it's only side play, that is easily adjuster out with the locking collars.
          • 43222
          Re: Headlights
          Roger------
          The bearings used for these assemblies are similar to what is known as a ball joint swivel bearing. Such bearings are available from industrial suppliers like McMaster-Carr and Grainger. The problem is I don't know if the bearings in the Corvette bearing assemblies are removable. If they are, the nylon sphere and metal outer race should be able to be pressed out of the frame and new ones pressed in.
          • Roger D.
            • June 3, 2014
            • 180
            Re: Headlights
            Hi Russ and thanks for responding. Yes the collar does adjust the side play but when you actually grab the door once set it still has to much side play meaning a wiggle action on the shaft itself. You can actually see the play between the shaft and the plastic ball bearing.
            Thanks!
            Roger
            • Roger D.
              • June 3, 2014
              • 180
              Re: Headlights
              Hi Joe, that will be a starting place for the new swivel bearing. Then I will go to the next step and see about the collar replacement.
              Thank You
              Roger
              • Roger D.
                • June 3, 2014
                • 180
                Re: Headlights
                Found someone finally who restored my pot metal swivels with a new plastic swivel as well as a new collar. They fit on the shaft perfect and there is no twist play with the ball and shaft. Happy days. Not sure how to post pictures so you will just have to take my word for it.
