Part numbers for taillights for 1963 - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Anyone have part numbers for rear taillights? Need LH inner- outer and RH inner-outer, could not find in my AIM. Thanks in advance.
  • Leif A.
    • August 31, 1997
    • 3654
    Re: Part numbers for tialights for 1963
    I don't have the GM original part numbers but here are reproductions using the original tooling.
    Browse RPUI's family of brands: The Right Stuff & Trim Parts. Everything you need to keep your vehicle in top shape.
    Leif
    • Jim D.
      • 2885
      http://www.trimparts.com/parts/index/
      You might as well buy a complete set because the new ones from TrimParts are beautiful and will make the remaining ones look bad. I've bought a few sets from them over the years. Highly recommended.
        • 43282
        Jerry------
        Complete lamp assemblies or just lenses?
        assemblies:
        LH outer------GM #910553
        LH, inner-----GM #910557
        RH, outer-----GM #910554
        RH, inner-----GM #910558
        lens only (all 4 positions)------GM #5954803
        ALL of the above are GM-discontinued.
        • David L.
          • July 31, 1980
          • 3310
          My 1963 (Oct. 1962) and 1964 (Oct. 1963) Chevrolet parts catalogs list the following in Gr. 2.679 for the 1963 Corvette "over the counter" tail & stop lamp assemblies:
          LH outer......928915 (replaced by 910417 in Mar. 1964 which was replaced by 910553 in May 1964)
          RH outer......928916 (replaced by 910418 in May 1964 which was replaced by 910554 in July 1964)
          LH inner.......928917 (replaced by 910557 in July 1964)
          RH inner......928918 (replaced by 910420 in Jan. 1964 which was replaced by 910558 in May 1964)
          Dave
          • John D.
            • December 1, 1979
            • 5507
            When I was first restoring my 63, the LWC the Chevy parts dealer was hollering at me. Joe said I was going to get him into trouble. (again)
            I kept ordering new taillights and they were all junk. Horrible plating and rough. Remember it well even though that was in 1979-80. John
            • Jim D.
              • 2885
              Prior to quality reproductions being available, I paid big $$ to have originals replated because NOS ones were complete garbage.
              • Alan D.
                • January 1, 2005
                • 2054
                The ones I purchased in 1972 were of a good quality, so I guess GM went down hill after that
                  • 43282
                  Alan------
                  As time goes on in the life of a part, the tooling used to produce it wears and deteriorates. During the period that the part is used in PRODUCTION, GM will usually refurbish or replace the tooling, as necessary, to keep producing high quality parts. Of course, SERVICE parts manufactured during the period that a part is used in PRODUCTION will benefit from this, too.
                  After a part is no longer used in PRODUCTION, with vastly fewer parts needed for sale in SERVICE, GM is usually not inclined to refurbish or replace tooling. So, they may continue manufacturing or having the part manufactured by an outside supplier and the quality progressively deteriorates. At some point, when someone adjudges the quality to be degraded too far, manufacture of the part ceases and the "discontinued sign goes up".
                    • 43282
                    Dave
                    Dave------
                    I don't think there was any significant visual difference between the early and final part numbers. The chances of finding NOS examples of the original part numbers is about as close to zilch as one could get.
                      Re: Part numbers for taillights for 1963
                      Jerry -
                      See UPC 12, sheet C1.00, item #5.
