E63 carpet ? - NCRS Discussion Boards
E63 carpet ?
  • Robert B.
    • March 1, 1992
    • 265
    E63 carpet ?
    So I bought the AL Knoch carpet set for my coupe and I checked the NCRS Judging guide and it states that the 63 carpeting should have a foam backing on all pcs. of carpet.
    Al Knock does not have a foam backing.Does anyone know what is correct. Does this get judged if so how. Thanks
    • 6956
    Re: E63 carpet ?
    Bob, are you sure there is not a gray foam backing pre molded to carpet, I am surprised that AK would not.
    • Robert B.
      • March 1, 1992
      • 265
      Re: E63 carpet ?
      need to correct my statement on the Al Knoch,carpet as it does have the light gray backing on it and it looks to be right on the money.
      • Bob R.
        • June 30, 2002
        • 1595
        Re: E63 carpet ?
        Robert,
        None of the reproduction carpets are 100% correct and you may see a deduct from the judges they usually find an issue with the heal pad in reproduction carpet and sometimes the weave is off.
        • Robert B.
          • March 1, 1992
          • 265
          Re: E63 carpet ?
          thanks. when I install the rear seat hold downs ? does that metal plate go over or under the carpet and is there a methodical way to install the carpet, like one piece should go first so on and so forth. Thanks again.
            • 6956
            Re: E63 carpet ?
            Bob the metal plates are interior color and go under carpets, Front carpets are pretty cut and dry, I would start from the rear wheel opening's left and right, these pieces require some trail fitting and positioning. make sure the carpet been laid out in a warm place for a few days to work out the wrinkles. or if your in a warmer climate outside in the sun will work.
