1956 Powerglide Adapter to Block
  • John C.
    • July 12, 2011
    • 122
    Hi All,
    Do the 5 top PG adapter to block bolts have lock washers on them?
    Thanks!
    John
    • June 1, 1974
    • 8334
    Re: 1956 Powerglide Adapter to Block
    did u check the assembly manual? i'd guess they weren't used but its been too long since i assembled our 55 and 57 with PG's. mike
    • John C.
      • July 12, 2011
      • 122
      Hi Mike,
      My assembly manual went with the car.....I just don't remember anymore.
      Thanks!
      John
      • Rod K.
        • April 1, 1990
        • 439
        The AIM for PG option pictorially shows lock washers but doesn't call them out as I assume they're part of the Engine Assy as delivered from Flint. Nothing shown for standard trans assy bell housing to block.
        • David B.
          • March 1, 1980
          • 680
          For the 56-57 Powerglide Transmission, 2 different bolt sizes are listed as being used for Flywheel Housing to Engine Block both used a plain 5/16 regular spring lock washer. The part number is 103320 it should be between .0080 & .0040 thick. The 2 bolts listed as being used are part #s 100125 & 100124. They are both listed as having a plain finish. #100124 is 5/16-18- 1 1/2" and #100125 is 5/16-18- 1 3/4" long. You should be able to determine what bolts go where.
          • John C.
            • July 12, 2011
            • 122
            Hi Rod and David,
            Ok, lock washers it is..... thank you so much!
            John
