FUEL LINE to FUEL PUMP QUESTION - '66 425hp
  • Jim F.
    Infrequent User
    • November 1, 1995
    • 8
    In restoring a 1966 425horse Corvette -- one area of confusion involves the fuel pump connection
  • Mike M.
    • June 1, 1974
    • 8332
    Re: FUEL LINE to FUEL PUMP QUESTION - '66 425hp
    if you in fact have a 66 425 fuel pump, it sounds like you have a 67 427 fuel pump to carb line. the 66 fuel pump line is bent on a 90 degree angle down at the fuel pump. the 67 lower end of the line doesn't have a 90 degree bend so the 67's do need a fitting between the fuel pump and the line to the carb. since 66 425 fuel pumps are unique , originals are very scarce and a lot of folks use a 67 fuel pump and 67 fitting/fuel line to carb. i have the original pump off my 66 425 but since i wasn't successful in finding a 66 bbc pump, i used a 67 bbc pump(which are or were plentiful back in the day) along with the 67 fitting/line. the judges are aware of the above switch-a-roo. mike
    • Jim F.
      Infrequent User
      • November 1, 1995
      • 8
      • Mike M.
        • June 1, 1974
        • 8332
        jim: i apologize as i got it ass backwards(shouldn't rely on memory) . anyway, the 66 425 pump utilizes a brass 90 degree elbow. the pump end of the 66 fuel line is not bent on a 90 degree angle. with the 67 BBC, the fuel line is bent on a 90 degree angle and threads directly into the 67 pump . sorry i confused you. if u pm me your email address, i'll send you a picture of the original pump off of 66 425 vin 18057, an AO smith body that left st louis on march 22, 1966. mike
        • Joe R.
          • June 1, 2006
          • 1822
          Hey Mike,
          How about posting it here so we all can see it? Inquiring minds want to know and all that!
          Joe
          • Vinnie P.
            Editor NCRS Restorer Magazine
            • June 1, 1990
            • 1539
            As per the good doc's request...original 66 425hp fuel pump off vin 18057
            • Joe R.
              • June 1, 2006
              • 1822
              Thanks be to Vinnie and the Doc!!!
              • John D.
                • December 1, 1979
                • 5507
                Jim, Some of the FI cars used a 5/16" fitting with 90 degree bend and 1/8" pipe end. I have seen the 3/8" fitting around my shop.
                Is the pump tapped for 1/8" or 1/4" pipe thread? John
                • Mike M.
                  • June 1, 1974
                  • 8332
                  john: put yer helmet on and get in the game. the original post referred to the 427/425 engine(which to the best of my knowledge diet have FI--unless u consider the one that sold at Smokey's auction). mike
                  • John D.
                    • December 1, 1979
                    • 5507
                    Dr. Mike, I know that. Was brain washed though and only know little bit about FIs.
                    The fitting for the 427/425 is readily available. JD
