66 muncie bolt finish
  • Donald H.
    • November 2, 2009
    • 2562
    Are the side cover and main/mid/tail case bolts black phosphate or zinc plated?
    Don Harris
  • Joe R.
    • August 1, 1976
    • 4546
    Re: 66 muncie bolt finish
    Black Phosphate or nothing at all! Have never seen any originals zinc plated!
    JR
    • Donald H.
      • November 2, 2009
      • 2562
      Thanks Joe. I'll clean an blacken them.
      Don
      Don Harris
      • Eric D.
        • February 1, 1992
        • 42
        1969 model year and earlier are just plain, unplated bolts...
        Hope this helps... Eric
          • 43133
          Eric------
          Yes, the side cover bolts were natural steel without any form of plating. However, the extension housing-to-main case bolts were black phosphate finished.
          • Eric D.
            • February 1, 1992
            • 42
            Joe, My original post I was going off memory (shouldn't do that), so I check my data base I keep on Muncie casting, bolt marking, tag numbers, VS P-numbers (started this late 1980's)...
            My 1966 Muncie data shows:
            Front cover---------no marks or M -------------------natural finish
            Side cover----------SBC-------------------------------natural finish
            Top tail--------------SBC------------------------------natural finish
            Long bottom tail-----L5-------------------------------Black finish
            Short bottom tail----G--------------------------------natural
            All of the info in my data comes from "virgin" Muncie 4-speeds that I have acquired, or restored for original owners, or restoration shop in the north eastern IL. ,,, south eastern WI. area...
            I have over 125 Muncie good cores in stock, plus 100's of main cases, tails, side covers, internals, and original bolts...
            I also have N.O.S. GM main cases, tails, side covers, inputs, clusters, speed gears, sycros etc... Plus an N.O.S. 1969 M-21 complete trans...
            Hope this helps... Crash
