I have what I think are the original hardtop bolts from my 65 and I have some new hardtop bolts from long island . The original ??? bolts have a heavy base washer and a shorter hex head than the new bolts .The new bolts have a thin base and a noticeable taller hex head . Are the short ones correct for a 65 and and were the longer ones correct for any other years ?
1965 hard top bolts
Re: 1965 hard top bolts
Bill------
Only one bolt was used from 1956 through 1975-------GM #3727973. Could this bolt have changed in minor ways over time? I'd say it's possible.In Appreciation of John Hinckley- Top
Which bolts, the ones in the deck or the ones in the qtr panel?I have what I think are the original hardtop bolts from my 65 and I have some new hardtop bolts from long island . The original ??? bolts have a heavy base washer and a shorter hex head than the new bolts .The new bolts have a thin base and a noticeable taller hex head . Are the short ones correct for a 65 and and were the longer ones correct for any other years ?
- Top
Loren------
Yes, the side bolts are different from the deck bolts. In my first post here I was referring only to the side bolts since I assumed that's what the question was about.
The deck bolt was GM #3837282 and was discontinued in 1980.In Appreciation of John Hinckley- Top
Bill
my car was a hardtop only car when I acquired it in 1970 and the side bolts you describe match what I have (yes I realize these could have been changed by original owner during the 5 years he had the car) have not seen the LI parts just fyi I added soft top many years ago and never use hardtop- Top
Assorted parts for the (top rear) deck bolts. On 2nd pic, I may have the wrong washer under the bolt head- Top
