Replace lower steering column bearing - NCRS Discussion Boards
  • Mike J.
    • January 1, 1999
    • 2
    Can I replace the lower steering column bearing on a early C3 without disassembling the complete Column?
  • Jim S.
    • August 31, 2001
    • 730
    Re: Replace lower steering column bearing
    You can disconnect the flex coupling nuts and then remove the steering gear from the frame. That will provide enough room to get at the lower bearing. However, it could very well be corroded in place and could be a real problem to remove it from the column jacket.
    I think that it would be far easier to remove the column from the car (leaving the steering gear in place). Now you will have complete access to the lower bearing. (It could be corroded in place.) This will also allow you to carefully inspect the steering column shaft, the condition of the lower bearing, etc.
    This paper describes how to remove the steering column from the car and replace the lower bearing. You will note that there is a lot of discussion about corrosion.
    Jim
    • Patrick B.
      • August 31, 1985
      • 1995
      JIm-- Do have any similar articles about 67 tele columns?
      • Jim S.
        • August 31, 2001
        • 730
        Yes, here is the link to two papers.http://jimshea.corvettefaq.com/?p=975Jim
        • Patrick B.
          • August 31, 1985
          • 1995
          thanks Jim
