anyone tried the 3M sound deadner instead of dynamat/hush mat for noise reduction in car, how about lizzard skin product??? thanks.
3M sound deadner vs dynamat etc.
Tags: None
- Top
Re: 3M sound deadner vs dynamat etc.
Michael,
I use neither as there is an insulating material sold at Lowe's that I like and use. It's about 1/4" thick and has aluminum foil on both sides so there is no problem using 3M upholster spray adhesive. It comes in a large roll and you have to cut it to fit but that's no problem either. Used it on several cars and it keeps the heat on the outside of the floor tunnel and the sound there also.
Please try it and report back as others may want to consider using it. Saves a lot of money and works well. You'll find it in the insulating department at Lowe's.
JR- Top
Joe Ray,
That type of radiant barrier was tested for my 2008 Restorer Article. See results chart below.
The radiant barrier did better than some of the others. Didn't test DynaMat. After talking with their Tech Support to get any floorboard heat reduction, two different types of their layers had to be applied and that made it took thick to be unnoticeable under the carpet for judging.
Gary
Floorboard Insulation Field Test Brand Floor Board Interior Surface Temp Material Surface Temp Temp Drop Floor to Top Insulation Temperature Reduction Percentage Corvette Central Ceramic Heat Barrier Kit 172 130 -42 24% Kool Mat 175 162 -13 7% Kool Mat with foil on floor side 176 159 -17 10% Energy Q Radiant Barrier 170 102 -68 40% HushMat 174 100 -74 43% Notes: 1 - Floorboard temp reading taken after car drive 4 hrs 2 - Insulation temp reading taken after car driven 4 hrs 3 - Temp measurements made with Raytek MT4 MiniTemp 4 - Outside temperature 96~100 degrees Floorboard Insulation "Kitchen" Lab Test Brand Cookie Sheet Temp Material Surface Temp Temp Drop Floor to Top Insulation Temperature Reduction Percentage Corvette Central Ceramic Heat Barrier Kit 199 134 -65 33% Kool Mat 196 170 -26 13% Kool Mat with foil on floor side 194 168 -26 13% Energy Q Radiant Barrier 194 90 -104 54% HushMat 195 86 -109 56% NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Gary,
Thanks for posting your test results - very telling. A question for you (or perhaps others) from your comment about two layers of Dynamat would probably not pass judging, do I understand that some types of after market insulating materials would pass judging? For example, your HushMat results are really impressive, if used under carpet would it pass judging? I understood that judges would peek under carpet where it can be rolled back without removing and if there was evidence of non-stock products there would be a point deduction. Can you or someone explain the judging rules on the use of after market floorboard insulation.Ed- Top
Ed,
I was under the impression that the judges are told not to touch the parts that they are judging but ask the owner to open, remove or demonstrate what the judges need for a visual inspection.
Maybe I'm wrong in that assumption but maybe that's the reason I don't have cars judged anymore.
Could the new head judge clarify this point?
JR- Top
The judging reference manual makes no provisions for removal, opening, etc except the pieces noted for removal in flight judging. Roy had made mention of specific items not to be opened or removed for judging in the Driveline a while back. I don't know if this has been added to the judging reference manual but is to be considered judging law. I too await Dave's call on lifting up carpets (back floor behind seats) in loose areas. This is a new one! Supposed to be a visual call no disassembly required.- Top
I just installed 1/2" Dynaliner on top of Dynamat (per manufacturer's instructions) on the floors and tunnel. The carpet still fits ok, but the carpet is a more cushioned because of the Dynaliner. Is that a problem for judging? Dynaliner also comes in 1/8" and 1/4" thickness, so that may make the carpet feel less cushioned.
Either way, it's definitely noticeable if the carpet cut out flaps for the seats are pulled back or the ashtray is removed.
The car isn't roadworthy yet, so no feedback about Dynamat's effectiveness.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I've learned most mods have unintended consequences.
The extra thickness of the 1/2" Dynaliner means that the seat and seat belt bolts are now too short. So I purchased a set of:
- Used OEM "long" seat belt bolts on ebay; see photos. Apparently some GM cars used a longer version of this shoulder bolt. They even have the "LL" head marking.
- Reproduction 78-81 Corvette seat bolts, which are apparently the same as the 1970 bolts but about 1/2" longer.
When they arrive, I'll let you know if this works.
Mark Edmondson
Dallas, Texas
Texas Chapter
