Is this a 62 flasher?
  • Willard M.
    • September 1, 1979
    • 422
    I found a light blue flasher with LF 224 on it. I have a tag saying it is for a 62 but I can't remember when I put that on. Is this really a 62 flasher and what is its value?
  • Ray C.
    Infrequent User
    • March 1, 1995
    • 18
    Re: Is this a 62 flasher?
    The 224 flasher is for a single lamp used on 64 to 66 Corvette with one rear signal.
    The 62 Corvette uses Signal Stat ZN332 or a Signal Stat 143. Value of 224 is unknown to me.
    • Willard M.
      • September 1, 1979
      • 422
      Ray-Thanks for the clarification. I have no idea why I mislabeled it.
      • Peter L.
        • June 1, 1983
        • 1930
        Willard - Not much. The LF 224 flasher you have is a LittelFuse flasher, but the late 60s & 70s Corvettes that used the 224 flashers used an OEM flasher made by Tung-Sol so the flasher used in those Corvettes was a TS 224. Pete
        • Willard M.
          • September 1, 1979
          • 422
          I was hoping that I had a rare $100 part. Not to be I guess. I'm not even sure the thing works so I need to plug it into my 66 and check it out.
