1967 Corvette L68 427/400 - looking for original cam specs - NCRS Discussion Boards
  • Ira C.
    • June 19, 2011
    • 1
    Pulled engine to clean detail and replace all gaskets etc. As we inspected parts, cam did not look good. Engine otherwise solid. Where can I find original spec cam as this cam did not have a part number...
  • Terry D.
    • May 31, 1987
    • 2697
    Re: 1967 Corvette L68 427/400 - looking for original cam specs
    If you google L-68 Chevy cam specs there all kinds of web sites. Check out the one on the Corvette Forum
      • 43285
      Ira-------
      How do you know that the cam is even the original cam? If the cam is original, there should be cast-in numbers 3904364 between the lobes or stamped in numbers on the end. If neither are present, I'd expect it's some sort of aftermarket cam.
      By the way, the L-68 camshaft is the same as the L-36 camshaft.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Ira, Yes it sounds like yours is not a original as Joe says.
        Original specs can be found at gmheritage.com for any year. See link in the stickys at top of the main TDB page.
        I recently acquired a Sealed Power L71 cam and lifters kit from Napa, CS165R. I believe the 427 hydraulic cam is their SEP CS636. Best to verify the application.
        http://www.napaonline.com/Catalog/Ca...636_0204440358
