Question on "S" terminal on the selonoid; starter#1109052 - NCRS Discussion Boards
  • Larry E.
    • November 30, 1989
    • 1635
    MVC-002F.JPGMVC-001F.JPGMVC-003F.JPGHelping my friend change out his starter for a 1977 Corvette; pictures below. The picture you see is the finish
    rebuilt starter from a local shop. If you notice the "S" terminal is closest to the engine block. I might be dreaming
    but the old one (sent to the shop) had the "S" teminal closest to the outside of the vehical. Don't know if the older
    selonoid was original or not. Question: Is it common to see the "S" terminal at various positions on the selonoid or
    is it always closest to the engine block as shown?? Thanks in advance. Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Mark E.
    • March 31, 1993
    • 4467
    Re: Question on "S" terminal on the selonoid; starter#1109052
    Your photo is typical of all solenoids of that vintage I've seen. S terminal is at the 3 o'clock position, or closest to block when installed.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jim L.
      • September 30, 1979
      • 1781
      I've never seen a solenoid on which the "S" terminal was NOT the terminal closest to the block.
        • January 31, 1988
        • 43160
        Jim-------
        I haven't either.
        • Larry E.
          • November 30, 1989
          • 1635
          Thanks for the return comments. Perhaps the old selonoid was wired wrong and I assumed it was the "S" terminal(did not pay too much attention to it when we dropped it); works fine now. Larry
          Larry
