I have a 1965 convertible with the original numbers matching 300 hp 327, I was looking into the carburetor because it is a holley and i know the 65 300 hp came with a carter afb. In my inquiry to why it has a holley I looked up the intake manifold numbers 3872783 and the numbers indicate that it is a 1966 300hp intake but the date stamped A 8 5 indicates it is made january 1965, much too early for the serial code to say its a 1966. I have attached photos of the casting numbers and if anyone knows about this I would love to know what is up with these numbers.
Intake Manifold Contradicting Numbers
Re: Intake Manifold Contradicting Numbers
Peter------
It's a very curious situation. It's possible the date code is a foundry mistake (i.e. the "5" should have been a "6"). If one were to assume the date code is correct, how does the date code line up with the build date of the car?
What is the part number and date code of the carburetor?In Appreciation of John Hinckley- Top
Peter------
What is the part number and date code of the carburetor?- Top
But also says accepts either a Carter or Holley carb, depending on application. Readily seen by identifying the multi-carb mounting flange [the cast "H" on yours] ....intake also used extensively as a service replacement. This seems to be your case.
Could someone with a Colvin book up to '64 check if he says that same # also used for service for years prior.
I don't see where 4160 carb models were even used for small blocks prior to the 1966 model year. What is the LIST # on the air horn?Last edited by Wayne M.; August 25, 2015, 12:58 PM.- Top
In digging around the interweb, I found several other 3872783 manifolds with very early '66 casting dates. Is it possible that late '65 Corvettes might have been equipped from the factory with this manifold?- Top
