Rochester confusion - NCRS Discussion Boards
Rochester confusion
  • Justin S.
    • July 3, 2013
    • 292
    Rochester confusion
    I have a 7040509 which is for a '70 big block 4 speed truck. The date code numbers are 1564. Doesn't this translate to the 156th day of 1964? Any help would be great .
  • Mike F.
    • April 25, 2011
    • 668
    Re: Rochester confusion
    It's most likely a service replacement carb, 156th day of 1974.
    Does it have a triangle casting on the front of it? If so, service replacement.
    • Justin S.
      • July 3, 2013
      • 292
      Thanks Mike. Yes that casting is there and after more investigating I found the letters RP all over it. Reproduction?
      • Mike E.
        • February 28, 1975
        • 5139
        RP equals Rochester Products. The carb you have would have been made by them, in 1974.
        • Mark E.
          • April 1, 1993
          • 4553
          I've read that the Q-Jet was introduced late in the '65 model year (for Chevy but not Corvette). They weren't used on Corvette until the C3s.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Mark E.
            • April 1, 1993
            • 4553
            Mike Furline- Is that a photo of your car's engine? The rubber hose splice looks like a real fire hazard. Consider making it a priority to replace it with an original style steel line. The Vette parts houses sell pre-bent lines for your engine and they're not expensive.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Mike F.
              • April 25, 2011
              • 668
              It was when I first bought it.
