Inspection Cover EL Headmark - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    After degreasing my Inspection Cover and Bell Housing on my '73 I found one missing lower inspection cover bolt, the three existing bolts have an "EL" Headmark.
    Trying to find a source to install the missing bolt, no aftermarket source sells an EL Headmark Bolt.
    They are selling either, a bolt with no headmark or an "E" Headmark.
    Searched info in TDB, and also nothing written in the '73-'74 or even '70-72 JG.
    Will look for an original piece.
    Any thoughts?
    • 3416
    Re: Inspection Cover EL Headmark
    Hi Gregory,
    You might want to contact Richard Fortier.
    He has amassed quite an assortment of original fasteners and could well have what you're looking for.
    He advertises in the Driveline.
    810-750-1472
      • 43222
      Any thoughts?
      Greg------
      This is an easy bolt to find. Millions of these were used for the bellhousing cover, timing cover, and oil pan on Chevrolet engines of the 60's, 70's, and 80's. Many of these have the "EL" headmarking---very common. Actually, both the "E" and "EL" headmarkings denoted the same manufacturer----ELCO Industries of Rockford, IL.
      • Scott P.
        • April 30, 1992
        • 178
        Any thoughts?
        Gregory, which one of the six do you want". Scott
        • Gregory G.
          • July 31, 2001
          • 203
          #5 EL
          Thank you,
          Scott
          • Robert I.
            • July 31, 2004
            • 164
            Anybody know what size those bolts are? Is there a source that tells you all the bolt sizes?
            ____________________
            Bob Immler
              • 43222
              Robert------
              1/4-20 X 3/8". They have an untrimmed ("indented") head, captured external tooth star washer, and zinc plated. The same bolts were used for oil pan, timing cover, and inspection cover applications.
