TV cable on C4 - NCRS Discussion Boards
TV cable on C4
  • Walter F.
    • October 22, 2006
    • 373
    TV cable on C4
    My TV cable is all the way to the end. Does this cable have to be reajusted from time to time ?
  • Mike E.
    • June 24, 2012
    • 920
    Re: TV cable on C4
    Walter,
    Forgive my stupidity....What's a TV cable?
    EDIT: Never mind....Figured it out. Have you seen this video?
    Mike
    • Ray G.
      • May 31, 1986
      • 1189
      Re: TV cable on C4
      Hello;
      The Throttle Valve cable should have been set correctly when originally installed.
      It is often thought of as some kind of a cure all. But the TV cable adjustment should not changed.
      The position of the cable housing bracket and its relationship to the throttle itself is crucial.
      Its main purpose is to apply the correct pressures inside the transmission when needed including shift point and downshift.
      my .02
      Ray
      I hope you dance
      • Jerome P.
        • October 22, 2006
        • 607
        Re: TV cable on C4
        Originally posted by Mike Eby (55078)
        Walter,
        Mike
        So what does the "T/V" in TV cable stand for? Something transmission I would guess.
        • Leif A.
          • August 31, 1997
          • 3654
          Re: TV cable on C4
          Throttle Valve
          Leif
