1966 Rear Spring Color? - NCRS Discussion Boards
  • Bryan W.
    • December 1, 2003
    • 52
    The judging manual reads "The rear spring is light grey, semi-gloss color" can anyone please give me an actual color name or better still a paint code for the correct color?
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: 1966 Rear Spring Color?
    Try to find a rattle can of "Zinc Rich Coating" to paint your spring leaves prior to assembly. This a pretty close match to the original paint used by the factory. I would not describe the color as semi-gloss. It is pretty much a flat grey. I bought mine at a big box hardware store in the aerosol paint aisle.
    tc
    • Wayne M.
      • March 1, 1980
      • 6414
      As far as shade, here's a comparison of the grey on the springs alongside the grey on the shock absorbers; both off my early '65 and never restored. I would say the spring coating used, called "Ionoclad" (sp ?), is several shades lighter than the shocks. IMO, not sure of the semi-gloss description. I'd say just a tad more gloss than flat sheen.
      c
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11363
        I use Rustoleum Navy Gray. After a sandblasting and Dupli-Color gray primer, I brush the Navy Gray on one side, then a few days drying time and do the other side. It takes forever to dry but it's very durable.
        Below is a F41 spring I just did for a '67.
        Below is a completed spring I did on a '67 a few years ago using the Navy Gray, albeit a Eaton reproduction.
        PB090015.jpgPB090018.jpgPB100021.jpgPB100022.jpgPB110028.jpgPB110029.jpgPB110030.jpgPB110031.jpgPB110033.jpg
          • 43273
          tc
          Tracy-------
          I would not describe it as semi-gloss, either. In fact, the Ionoclad was decidedly flat. I would say no gloss, at all.
          • Bryan W.
            • December 1, 2003
            • 52
            Thanks to you all. I now have some good information and a more accurate picture/s on how to proceed.
            I will go shopping for a local product for the job. Thanks again.
            • Bill L.
              • April 1, 1985
              • 349
              I have used Krylon New Ford Grey with very good results on shocks and the rear spring ---
              (Blasphemy!!! But it looks pretty close--- "I know ---close is relative !!!")...
              Here are the specifics:
              Krylon EDE1611 / De1611 New Ford Grey
              O'Reilly has it listed on their site ---
              Regards
              Bill
