1955 wheel brake cylinders
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 161
    Working on 55 #63, all 4 wheel cylinders were replaced, Would someone be able to provide original casting #s to replace cylinders with resleeved originals. Thanks!!
    • 43129
    Re: 1955 wheel brake cylinders
    Lynn------
    According to GM the casting numbers were 5453822, front, and 5453820, rear. However, I can't verify that from personal experience.
    • John S.
      • July 30, 2009
      • 640
      Lynn------
      fronts are 821 and 822. rears are the 820 which needs the brass block and drilled bolt. car is neat and very original. I hope the owner don't try to over restore car. master cylinder also appears incorrect. there appears to be a fitting in the passenger side boss. one other item the owner might want to look for is a 085 vacuum advance. the car appears to have a 104.
      • Lynn L.
        1953-55 Team Leader
        • February 1, 2000
        • 161
        John, thanks for help. Lynn
