Joe I was going to wait a while but I saw you chimed in on a pulley thread recently. I've looked at past archives and the AIM. I've never got a definitive answer or found for that matter the correct pulleys for a 68 L79 with A/C and Power Steering. This is a HP motor. I understand the crank and water pump have a dual pulley. Mine aren't what I've seen in past threads. I do have an add on pulley on the water pump. At your convenience could I have the correct pulley numbers for my application.i believe the only pulley that was correct so far was my smog pump.thank you as always Jeff
1968 L79 pulleys and belt configurations. I understand
Re: 1968 L79 pulleys and belt configurations. I understand
Jeff------
Basically, the 1968 L-79 with N-40 and C-60 pulley set-up is the same as 300 HP with N-40 and C-60 although there are a few differences.
waterpump, rear, 2 groove-------------------------GM #3890419
waterpump, front, 1 groove (AIR driver)-----------GM #3883234
crankshaft, rear, 2 groove -------------------------GM #3850838
crankshaft, front, 1 groove (p/s driver)------------GM #3751232
power steering pump-------------------------------GM #3770509
AIR pump--------------------------------------------GM #3917234
Alternator (pulley with integral fan)-----------------GM #3909817In Appreciation of John Hinckley- Top
Joe the crankshaft pulley that was on there was 3911013. What was the application for this pulley?68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
2014 Arctic White Z51 Vert. (Wifes)- Top
Jeff-------
The 3911013 was used for most 1968-74 small blocks with C-60. However, my information indicates that the 1968 L-79 was an exception. The 3850838 and 3911013 are very similar pulleys with the 3911013 being a little larger in OD.In Appreciation of John Hinckley- Top
Joe, the diameter of pulley 3911013 is 7 11/16. The diameter of pulley 3751232 is 6 3/4. They don't look like they could be sandwiched together. This car is original A/C but I'm adding the PS. Looks like when C60 is added the pullieys you mentioned are used. The water pump pulley is 3876846 with a diameter of 6 3/16. Add on pulley is 3883235 with diameter of 5 15/16. As always very interesting.68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
Jeff------
Yes, the pulleys you mentioned are the correct ones for the application with C-60 but without N-40.
The fact that the 3911013 and 3751232 are different OD's should not, by itself, affect whether the 2 will nest together. As a matter of fact, the GM #3850838 is a considerably different OD than the 3751232 but those two pulleys will nest together perfectly. I have NOS examples of both the 3911013 and 3751232 but I'm too sore and lazy to go dig them out and see if they'll nest.In Appreciation of John Hinckley- Top
Jeff------
In your third photo it looks like you might have the pulleys "back-to-back" although I can't really see the 3911013 too well in that photo..In Appreciation of John Hinckley- Top
Well, I remember you saying the single goes in front. So I didn't know any other way they would fit. LOL68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
Jeff------
The single groove does go in front. However, it fits into the front (dished) of the 2 groove pulley.In Appreciation of John Hinckley- Top
