67' French locks on half shaft; Buckle/twist upon torque - NCRS Discussion Boards
  • Dave K.
    • January 24, 2013
    • 278
    Stupid question....or maybe I have some cheap french locks?? Whenever I try to torque the bolt to 60 ft. lbs the french lock starts to bend/twist. I've tried putting silicone on the lock so the bolt has less friction but still no luck. I bought the locks from CC; however, they appear to be aluminum. What am I doing wrong?..or are there better locks on the market?
    • 43251
    Re: 67' French locks on half shaft; Buckle/twist upon torque
    Dave------
    I can tell you that the exact same problem will be experienced even with the GM locks, GM #3860543 (no longer available). I use a bit of anti-seize compound but the problem still occurs. Stainless steel reproductions are a little harder and more resilient.
    • Ray G.
      • May 31, 1986
      • 1189
      Hello;
      We have had some success by polishing the area of the bolt contacting the french lock the same as chrome or stainless.
      A buffing wheel and white rouge.
      The process doesn't always stop the twisting of the french lock, but it seems to help along with Joe's suggestion of a little dab of anti-seize.
      Ray
      I hope you dance
