Muncie 4 speed case cleaning . - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    I am cleaning my 4 speed the main case and the shift cover came out great useing my parts washer & simple green . the tail housing is clean but looks like crap . it is very rough. What are people using to get the alum. clean & looking like new . I have a glass beader but I dont want to use it or use paint .
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Muncie 4 speed case cleaning .
    lacquer thinner, then purple power
      • April 1, 2000
      • 477
      In my experience, the tail housings are a much lower quality, both in terms of material used, i.e. more of a pot metal and darker, and lower quality of casting. They didn't need to be as strong and high quality as the main case and mid-plate, etc. I've never gotten the tail housings to look as nice, but IMHO that's how they were originally too.
        • 43222
        Jack-------
        The Muncie main cases and extension housings were different types of castings. The main case was an aluminum sand casting. The extension housings were an aluminum die casting. Sand cast aluminum evidences a different surface texture and coloration compared to aluminum die castings. So, the main case and extension housing always appeared of a different texture and coloration, even when they were brand new.
        • Eric D.
          • February 1, 1992
          • 42
          I have an NOS 1969 M-21 never installed, and the tail housing is darker than the main case...
          Hope this helps... Eric
          • Jeff P.
            • 799
            I just had my M20 restored by Davids 4 Speeds. He has a large tumbler which did an awsome job on the casings.
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
