1963 Spare tire lock - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1309
    Re: 1963 Spare tire lock
    Frank,
    Can you post a picture of the bottom of the lower lock with the pad attached? I want to install mine and I could use a clear picture of the bottom.
    Jerry
    • Gary B.
      • February 1, 1997
      • 7064
      Originally posted by Gerald Coia (11656)
      Frank,
      Jerry
      Jerry,
      Here’s a photo of an original, early ‘63 tire lock, looking at the pad on the underside.
      And here’s a photo of the anti-rattle pad sold by Long Island Corvette.
      You’ll find that the pad is wider than the lock, and it will overhang the lock on both sides. The front of the LIC bag shows (in a poor cartoon sketch) how the pad is positioned on the lock.
      Most original locks with original pads won’t still have the obvious overhangs on the two sides because the rubber becomes friable with age and the overhanging edges wear away.
      One final comment is that the LIC reproduction pad is die cut from a sheet of foam and it’s lacking a bevel cut on the full width of the center third on the bottom in photo #2. The lack of that bevel cut was confirmed to me by Kim Cohen from LIC.
      Gary
      • Gerald C.
        • June 30, 1987
        • 1309
        #18
        Thanks Gary, I started a Thread about finding a tumbler that will take the ignition/lock key. Do you have any? The aftermarket lock will not accept the ignition key groove.
        Jerry
