I have a C4 and my brother a 57 Ford Fairlane 500 coupe. We use our cars from late spring till late fall. Both cars are stored in unheated garages and stabil is put in the fuel tanks and the cars are covered with a car cover and a trickle charger is placed on the battery. We both live in New York and the winters are cold and wet. Is this enough care for a 5 month storage or should other measures be taken ? Should the cars be started and run at idle during that 5 month period?
5 Month storage
Re: 5 Month storage
Same here, but I put plastic on the floor to try and minimize any condensation that seems to occur due to the cold floor if there is a more humid day.Vice-Chairman (West), Michigan Chapter NCRS
Re: 5 Month storage
Walter -I have a C4 and my brother a 57 Ford Fairlane 500 coupe. We use our cars from late spring till late fall. Both cars are stored in unheated garages and stabil is put in the fuel tanks and the cars are covered with a car cover and a trickle charger is placed on the battery. We both live in New York and the winters are cold and wet. Is this enough care for a 5 month storage or should other measures be taken ? Should the cars be started and run at idle during that 5 month period?
Nope, don't start them unless you're going to drive them at least 10-15 miles; just leave them alone and start them in the Spring. Seals don't "dry out".- Top
Re: 5 Month storage
Five months is not very long. You don't need Stabil or any other fuel additive - the colder the storage temperature the less propensity for the fuel to oxidize and form gum... just fill the tank with fresh fuel before storage and air up the tires to at least 35 psi.
Oil changes should always be done before storage. IF the oil is still clean - say no more than a few hundred miles since the last change - it's okay to go a couple of years, but cars without PCV systems will contaminate the oil faster than PCV equipped engines, so more frequent changes may be in order - at least once a year.
There are zillions of "winter storage" threads in the archives.
Duke- Top
