Crease in C3 Frame -- Is this a Problem? - NCRS Discussion Boards
  • David C.
    • June 30, 2006
    • 126
    I recently acquired a 1973 Corvette, and I am new to the hobby.
    I was looking under the frame and realized there is a crease / dent in the underside of the passenger side frame rail. It is just ahead of the door front opening, and is about 6 - 7" long. In the general area of where a lift or jackstand would go. The depth of the crease is approx 1/8" to 3/16" at the deepest. I have attached two photos below. There is a smaller crease in the same area on the driver's side. Otherwise the frame appears straight and is very clean and virtually rust free.
    Should I be concerned about this?
  • Timothy B.
    • April 30, 1983
    • 5197
    Re: Crease in C3 Frame -- Is this a Problem?
    David, My vote is no, the dent will not cause any problems.
    • John D.
      • June 30, 1991
      • 875
      I agree not to worry. It could be due to someone jacking up the car in the middle to raise the whole side of the car...
      • Michael G.
        • January 1, 1997
        • 1251
        Ditto.........move on.
        • Dale C.
          • November 1, 1999
          • 844
          Looks like it should be fine but I would stay clear of that area for lifting or jacking.
          Dale
          • Steve L.
            • June 30, 2001
            • 763
            I've had mine lifted in that area many times and there was no creases or dents. Based on my experience, there was something else that dented it other than a jack.
            Steve L
            73 coupe since new
            Capital Corvette Club
            Ottawa, Canada
            • Dale C.
              • November 1, 1999
              • 844
              Steve
              I'm no metallurgy expert and do agree that jacking didn't cause this crease. I was just thinking that what did cause it was pretty substantial and may have done more than what we can see, especially in a picture. It is probably still structurally sufficient but, minimally, lost some integrity due the actual deformation and/or possibly created stress issues from the impact. As we don't know, I just thought it best to pamper that area and not mess with it. I wish I had been more careful while working the frame as I just had a jack slip while lifting and now I'm redoing a rocker panel.
              Dale
