Attaching metal to fiberglass - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1281
    Hi, I need to attach a metal bracket to the fiberglass in my headlight buckets. Any thoughts on the "glue" I should use? Epoxy??? Thanks,Jerry
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: Attaching metal to fiberglass
    Jerry,
    My vote is for J&B weld.
    • Joe R.
      • July 31, 1976
      • 4550
      There is a 3M product designed for specifically what you want. Go to your paint supplier and ask for the 3M pamplet on adhesives.
      It's a two part adhesive and you will need a gun that can be supplied by the paint supplier. There will be two mixing tips supplied with the 3M adhesive and you can purchase more in a pack of 5.
      JR
      • Joe C.
        • August 31, 1999
        • 4598
        Ordinary polyester fiberglass adhesive bonds to clean metal. No need for epoxies.
          • 15667
          The birdcage bonding strips that hold body panels are riveted to the birdcage, so if the joint is not visible you can use rivets.
