1965 corvette convertible color request - NCRS Discussion Boards
  • John S.
    • January 1, 1998
    • 81
    I would like to know the correct color for a 1965 corvette convertible which is Glen Green and a saddle interior. The color I do not know is where the dash pads connect to the car there is a ?panel which is riveted to the car. Is this panel body color or interior color?
  • Joseph T.
    • March 1, 1986
    • 169
    Re: 1965 corvette convertible color request
    Typically with contrasting interior and exterior colors -the riveted part of the dash pads will be painted body color. Possibly even with a little overspray on the dash pad eyebrows
    • James W.
      • December 1, 1990
      • 2671
      To answer your question, here are some pictures.
      Hope this helps.
      James West
        The main fiberglass dash panel (see photo below) is painted interior trim color (saddle), and the end tabs (where the five rivets are on each end) on your car should be masked and painted Glen Green.
        • Mike E.
          • June 24, 2012
          • 920
          [ATTACH=CONFIG]55073[/ATTACH]
          John,
          I've been trying to understand where on the line this happend. If the dash was installed after the body shop where did this get painted? Should Glen Green car with a black (STD) interior be painted?
          Mike
            Originally posted by Mike Eby (55078)
            John,
            Mike
            Mike -
            The masking and painting of the dash end tabs was done in Final Paint Repair, which was after Roll-Test and Water Test, and prior to the Final Trim Line, where the interior soft trim was installed. If the interior and exterior colors were the same, the tabs didn't get painted and the rivet heads showed as black oxide; if the colors were different, the tabs (and the rivets) got painted.
